User Tools
Site Tools
model_config:floureon_h101_devo10_inverted_flight_trainer
Floureon H101 Devo10 Inverted flight Trainer
Hi Guys,
here is a Model.ini for The H101 - but this one is a bit special. I did this for using this quad (and maybe others in this style as well) as a 3D trainer, for train the inverted flight views.
While flipping it to inverted mode, the Quad negates its Controls by itself - not good for beeing a trainer.
But it is possible to start inverted with this quad - So I Had the Idea to add a switch that inverts the Controls like they are on a Heli that is flying upside down.
Short explanation of the model file:
FMOD0: High Rates, While in FMOD0, AILE D/R1 increases the rates a little bit more
FMOD1: High Rates, Flips enabled
FMOD2: low Rates
MIX1: Half Flips
MIX2: Full Flips - if needed in other Flight Modes than FMOD1
GEAR1: Inverts Throttle (pay attention while toggling with no TH!) and the other relevant channels.
RUDD D/R1: Throttle Hold
Counter Reset is on TRIM_L+
Note: No Headless Mode, No RTH configured!
Have Fun!
Greetz
Domsen
model6
model_config/floureon_h101_devo10_inverted_flight_trainer.txt (44585 views) · Last modified: 2016/01/31 14:15 by SirDomsen
