model_config:genius_cp
Genius CP
Genius cp with the brushless main motor mod.
current file is set the stick mode 4 which i fly on so you need to select your stick mode if you use a different stick mode.
performs really well but you might prefer to tweak a few settings..
settings are not aggressive but not for beginner.
the protocal is set to Devo.
has fixed ID if you don't want fixed then before you bind reset the ID to none.
has the mix switch set for the gyro sensitivity with 0 being the highest gyro sense.
also has the rudder DR switch set for the Throttle Hold…flipping this switch kills the motor but retains cyclic pitch travel
model_config/genius_cp.txt (57911 views) · Last modified: 2012/09/09 20:27 by magic_marty
