model_config:help_converting_my_supercp_to_phoenix_model_-_fmod
Help converting my SuperCP to Phoenix Model - FMOD
Hi, I took my SuperCP model which is working fine and simply changed the transmitter protocol to PPM and changed the model name.
This is working in Phoenix, except my FMod switches do not work as expected.
It goes to 100% throttle, but it sees the pitch at throttle down not as 100% negative. The heli takes off and goes sky high like the pitch is at 100% positive.
I could sure use some help with this one as I'm brand new to deviation, the Super CP is my first heli and I just got into this sport about 6 weeks ago.
What do i need to do to make my FMOD1 and FMOD2 work in Phoenix like they work with my SuperCp in real life?
Thanks alot!
model_config/help_converting_my_supercp_to_phoenix_model_-_fmod.txt (21670 views) · Last modified: 2015/01/17 14:28 by mswanson25
