User Tools
Site Tools
model_config:lanyu_asw28
Lanyu ASW28
This may be useful to someone. May also be good starting point for other gliders.
Devo 8s Mode 2
ADIF Aileron differencial
E>F Elevator > Flap mixing
A>R Aileron > Rudder mix. R/DR sw
F>A Flap > Aileron mix. AIL/DR sw
F>E Flap > Elevator.
CROW Airbrakes. Gear sw
AIL.T Aileron Trim. Trims ailerons up/down together.
Flap1, Flap2. Mix1 Mix2 sw
A>F Aileron > Flap mix. ELE/DR sw
DFL.T Dual Flap Trim. R Trim. Trims flaps opposite to each other.
Flaps L Trim
Motor brake
This is for DSM2 with Spectrum AR7000 rx. Have done another setup for PPM with Corona rx.
Have setup sheets with descriptions for ASW28.
Setup sheets below are very useful when setting up a new model from scratch.
Will add more info.
[video]http://https://www.youtube.com/watch?v=_jpaFOaBOm0&feature=youtu.be[/video]
model30_2014-09-09
model_config/lanyu_asw28.txt (52552 views) · Last modified: 2014/08/01 07:25 by Birdman
