model_config:trex450pro_fbl_2801_devo_-_beastx_hobbymate
Trex450Pro FBL 2801 & Devo - BeastX/HobbyMate
A special Thank you goes to Tom Z, because without his guides I would have given up. These are for:
Trex 450 Pro FBL with Beastx/Hobbymate sytem, not sure about Tarot/CopterX but should be close. One file is for a 2801RX and the other for Devo's.
All sticks and movement are set for 100%. Gyro is set at 70 and -50. Expo/Dr at 100/Line. Throttle Hold on Rudd DR Switch, set to full movement for auto-rotation.
Remember to remove the name after model# and if anyone see's anything wrong…..please let me know.
***Adjust the scalar for Channel 7. Its off, I set it up with Old 2801 Numbers causing tail wag. New files have better numbers, but will still have to be adjusted for your Heli.
model_config/trex450pro_fbl_2801_devo_-_beastx_hobbymate.txt (70731 views) · Last modified: 2013/01/26 12:36 by Rambosmurf
