User Tools
Site Tools
model_config:walkera_cp_helicopters_-_ultra_beginner_settings
Walkera CP Helicopters - Ultra Beginner Settings
This model is different than my Beginner Settings model posted on this web site. It is even tamer and will hover at about 1 line above the half stick throttle mark. I made this model for the beginner who is flying a CP helicopter for the first time. This model is made just to hover and fly around.
This model will work on the following helicopters.
  • Walkera V120D02S * Walkera V120D02S V2 * Walkera Mini CP * Walkera Super CP * Walkera Genius CP V1/V2 * Walkera V100D08 * Walkera Master CP
[li]Walkera V450D01/D03
This model will work in the Walkera 4f200lm but you need to reverse ALIE and RUDD.
This model will work in the Walkera V200D03 but you need to reverse ELEV and RUDD.
*If you are using the V120D02S, V120D02S V2, Genius CP V1 with the WK-2801 Pro compatible Receiver change Protocol=DEVO to Protocol=WK2801.
Model 39 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
I test flew this model with with my Devo 10 with my Mini CP and V120D02S V2.
I can't test fly it with my Master CP due to the extremely cold weather, snow, and high winds outside.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
If you fly outside in wind use ST- 2 which has negative pitch which can pull the heli down in wind.
  • Very Low Pitch to make the heli more tame. * Hover about 1 line above the half stick throttle mark. This is helpful for beginners to learn on. * Low Dual Rates and Expo to tame the heli down.
[li]Throttle Hold on the RUDD D/R switch.
Zero Degree Pitch when throttle hold is on.
This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike.[/li]
  • 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DEVO * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Flight Mode
Normal: No negative pitch at low stick. Hover about 1 line above the half stick throttle mark.
ST-1: Same as Normal Mode.
ST-2: -2* negative pitch so you can fly in wind if you want to. It will hover about 1 line above the half stick throttle mark.
You can also use this mode to get use to having negative pitch at low stick.
I left out full +/- Stunt modes as a beginner will not use them. Also there is no chance of accidentally selecting full +/- pitch.
Throttle Curve
Normal Mode: Linear Curve
ST- 1: Linear Curve
ST- 2: Linear Curve
Pitch Curve
Normal: No negative pitch. Helicopter will hover about 1 line above the half stick throttle mark.
ST-2: -2* negative pitch. Helicopter will hover about 1 line above half the stick throttle mark.
Gyro Gain is set to 64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO - ELEV, AILE, RUDD are all the the AILE switch for quick and easy changing in hover or flight.
Don't try to flip or 3D with these settings.
Switch Position - This setting is for hovering and slow forward flight only.
0- ELEV D/R = 30% EXP -10%
0- AILE D/R = 30% EXP -10%
RUDD D/R = 100% EXP +20%
Switch Position
1- ELEV D/R = 50% EXP +30%
1- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model39_2014-02-01
model_config/walkera_cp_helicopters_-_ultra_beginner_settings.txt (81703 views) · Last modified: 2014/01/30 17:33 by Tom Z
