User Tools
Site Tools
model_config:wl_toys_-_v911
WL Toys - V911
Attached is a config file for the WL Toys V911 along with an icon for the model.
Note that you need to complete the Flysky Hardware Mod in order to be able to use the Flysky protocol and bind to the V911. The document containing the details on how to complete the mod is available in the download section.
This config uses Fixed ID (1111) to bind to the model as I find it easier to bind using the “Bind” button in the GUI. Feel free to edit the config (in a text editor or directly in the GUI before turning on the model) if you do not want to use fixed ID.
Three flight modes are available and assigned to the FMODE switch.
Base settings are as follow:
AIL: [Reversed] - Min/Max [-100;100] - Scale [100] - Subtrim [-10,00]
ELE: [Reversed] - Min/Max [-100;100] - Scale [100] - Subtrim [-00,00]
THR: [Normal] - Min/Max [-100;100] - Scale [100] - Subtrim [-00,00]
RUD: [Reversed] - Min/Max [-100;100] - Scale [65] Subtrim [-5,-1]
Subtrim on AIL and RUD to counterbalance the birth defects of the model.
Scale reduced to 65 on RUD to counteract piro effect and still leave plenty rudder action.
Flight Modes are as follow:
Switch flight modes using the FMODE switch.
| FMODE0=Low Rates | Curve | Expo Rate | Scale | AIL | EXPO | +15 | 55 | ELE | EXPO | +15 | 55 | THR | 1-to-1 | N/A | 100 | RUD | EXPO | -6 | 70
| FMODE1=Med Rates | Curve | Expo Rate | Scale | AIL | EXPO | +15 | 70 | ELE | EXPO | +15 | 70 | THR | 1-to-1 | N/A | 100 | RUD | EXPO | -11 | 83
| FMODE2=High Rates | Curve | Expo Rate | Scale | AIL | EXPO | +15 | 95 | ELE | EXPO | +15 | 95 | THR | 1-to-1 | N/A | 100 | RUD | EXPO | -22 | 95
[i]Notes:
1 - Neg Expo on Rudder for fast response and to reduce stick travel on the TX in order to avoid disrupting Throttle.
2 - Trim steps value have been increased as well - see the TRIM screen once model file is loaded.[/i]
Have fun.
Feedback welcome.
v911
model_config/wl_toys_-_v911.txt (49079 views) · Last modified: 2012/09/12 17:53 by rototophe
