User Tools
Site Tools
model_config:wltoys_v931_v977_v2
WLToys V931 (V977 V2)
Devo8s
Has trims for 6G (when hovering in 6g mode, use trims as normal)
11CH
CH1 = Thr
CH2 = Ail
CH3 = Ele
CH4 = Rud
CH5 = D/R > AIL DR0 = -100 > Low (Normal)
…………………AIL DR1 = 100 > High
CH6 = TH > RUD DR0 = -100 > Off
……………….RUD DR1 = 100 > On
CH7 = FM > FMOD0 = -100 > Normal
………………..FMOD1 = 100 > 3D (idle up)
CH8 = 6G > GEAR 0 = -100 > On (6 axis)
………………..GEAR1 = 100 > Off (3 axis)
CH9 = Pitch Travel Adjust
CH10 = Ail Trim
CH11 = Ele Trim
MIX0 = Rates 60, Expo 50
MIX1 = Rates 80, Expo 25
MIX2 = Rates 100, Expo 0
Default settings (all switches 0)
Flight Mode = Normal
6 Axis = On
Rates = Low (Normal)
Hold = Off
Mix = Rates 60, Expo 50
Subject to change with more flights.
Will add more info if any interest.
Bm
v931
model_config/wltoys_v931_v977_v2.txt (60832 views) · Last modified: 2015/11/25 22:52 by Birdman
