7. Main Menu¶
_images/main_menu.png
The main menu selections of the Deviation firmware are accessed by momentarily pressing the ENT button on the bottom right of the transmitter. The main menu consists of the following four options: Model menu, Transmitter menu, USB and About Deviation.
All settings which pertain to the usage of your Devention transmitter are accessed from the main menu. They include model options, language selection, display options, buzzer, vibration, stick mode, calibration, USB connectivity as well as version information.
7.1. Model menu¶
The model menu is the area within Deviation that you can configure the type of aircraft you are flying. All model data is managed and saved within this menu selection. Details of the menu are located in section 9   Model menu.
7.2. Transmitter menu¶
The transmitter menu allows you to select transmitter-specific options as well as monitor channel output & stick input, and monitor telemetry (if available). Details of the menu are located in section 8   Transmitter Menu.
7.3. USB¶
_images/usb.png
The USB page can be accessed by selecting ‘USB’ from the main menu. USB mode can then be toggled on/off to enable access to the transmitter’s file-system from a USB equipped computer. In this mode the file system of Deviation is accessible as a mass storage device. This will allow you to move files back and forth between the Deviation file-system and a PC. All configuration files are accessible in this mode.
NOTE: Entering USB mode should never be done while the model is bound, USB usage will disrupt signal transmission!
7.4. About Deviation¶
_images/about.png
The Deviation release version can be accessed by selecting ‘About Deviation’ from the main menu.
Table Of Contents
  • 7. Main Menu
    • 7.1. Model menu
    • 7.2. Transmitter menu
    • 7.3. USB
    • 7.4. About Deviation
Related Topics
  • Documentation overview
    • Previous: 6. Navigating
    • Next: 8. Transmitter Menu
This Page
  • Show Source
Quick search
Enter search terms or a module, class or function name.
©2015, ugkg. | Powered by Sphinx 1.3.1 & Alabaster 0.7.7 | Page source
