6. Navigating¶
The transmitter menus can be navigated via the physical buttons UP, D(ow)N, L(eft), R(ight), ENT(er), EX(i)T. All buttons and switches have been marked with the same descriptions as used in this manual.
There are several GUI elements that are used to configure settings on the transmitter
Buttons: Buttons can be selected to either toggle a setting or to enter a new menu.
Spin-Boxes: Spin-boxes are used to select one of multiple values.
There are two types of spin-boxes available:
  1. Spin-boxes consisting of both arrows and a 3d button may act both as spin-boxes (for selecting a value) and as a button (which can have various effects).
  2. Spin-boxes that contain only arrows and a white label do not act as buttons, and are only used for value selection.
Note that a spin-box may change between being selectable or not for different values of the spin-box.
The main menu is accessed by pressing ‘ENT’ on the main menu.
6.1. Navigating¶
  • On all menu pages, ‘UP’ and ‘DN’ are used to navigate to the previous/next item.
  • The ‘R+’ and ‘L-’ buttons are used on spin-box widgets to increase or decrease the selected value. In some cases holding down the button will use larger step values to move more quickly to the desired value.
  • For buttons and rounded-spin-boxes, pressing ‘ENT’ will press the button,
  • Pressing ‘EXT’ will remove selection form the current item. A long-press of ‘EXT’ will exit one (1) menu level.
Table Of Contents
  • 6. Navigating
    • 6.1. Navigating
Related Topics
  • Documentation overview
    • Previous: 5. Main Page
    • Next: 7. Main Menu
This Page
  • Show Source
Quick search
Enter search terms or a module, class or function name.
©2015, ugkg. | Powered by Sphinx 1.3.1 & Alabaster 0.7.7 | Page source
