adding_3_position_virtual_switch_to_devo_7e
Last revision Both sides next revision | |||
adding_3_position_virtual_switch_to_devo_7e [2017/10/15 12:41] MikeNH created |
adding_3_position_virtual_switch_to_devo_7e [2017/10/15 17:11] MikeNH |
Line 4: | Line 4: | ||
What do we have to give up to create virtual switches? The trim switches. How much use does the throttle trim get? How much use does the elevator trim get? If you agree that these trim switches are rarely, if ever used, in the following steps, we will put them to good use as virtual 3 position switches. | What do we have to give up to create virtual switches? The trim switches. How much use does the throttle trim get? How much use does the elevator trim get? If you agree that these trim switches are rarely, if ever used, in the following steps, we will put them to good use as virtual 3 position switches. | ||
- | The Deviation version we are working with is devo7e-v5.0.0-d88c192 | + | The Deviation version we are working with is devo7e-v5.0.0-d88c192. However, all current Deviation versions are capable of implementing virtual switches. |
The general process is to first reassign the chosen trim's step value. (More about step value later). Then we create a virtual switch using the chosen trim switch. Finally, we assign a channel to the virtual switch. This is all done within a specific model because you may have craft that need these trim switches. | The general process is to first reassign the chosen trim's step value. (More about step value later). Then we create a virtual switch using the chosen trim switch. Finally, we assign a channel to the virtual switch. This is all done within a specific model because you may have craft that need these trim switches. |
adding_3_position_virtual_switch_to_devo_7e.txt (10213 views) ยท Last modified: 2017/10/24 19:25 by MikeNH
