building_the_multi-module
building_the_multi-module [2016/04/15 07:25] FDR [Additional requirements] |
building_the_multi-module [2016/04/15 07:26] FDR [Installation] |
Line 61: | Line 61: | ||
- | The module can be installed as any other transceiver module.Installation instructions are can be found here: [[ModuleInstallation]] | + | The module can be installed as any other transceiver module. Installation instructions are can be found here: [[rf_module_installation|Module Installation]] |
==== Programming ==== | ==== Programming ==== |
building_the_multi-module.txt (307584 views) ยท Last modified: 2017/01/23 00:21 by FDR
