building_the_multi-module
building_the_multi-module [2016/04/15 07:26] FDR [Installation] |
building_the_multi-module [2017/01/23 00:21] FDR https |
The board can be ordered from Oshpark here: | The board can be ordered from Oshpark here: | ||
- | [[http://oshpark.com/shared_projects/nNRSCkjI|V1.2]] | + | [[https://oshpark.com/shared_projects/nNRSCkjI|V1.2]] |
or [[https://oshpark.com/shared_projects/Df3iWl1J|V1.3]] <-- suggested | or [[https://oshpark.com/shared_projects/Df3iWl1J|V1.3]] <-- suggested | ||
Line 69: | Line 69: | ||
**//NOTE: If you have any of the transceiver modules installed, you should use a 3.3V programmer (or use the DEVO programming method below) as the modules cannot take 5V input //** | **//NOTE: If you have any of the transceiver modules installed, you should use a 3.3V programmer (or use the DEVO programming method below) as the modules cannot take 5V input //** | ||
- | You need to obtain the latest avr.hex file from here: http://deviationtx.com/downloads-new/category/4-multi-module | + | You need to obtain the latest avr.hex file from here: https://www.deviationtx.com/downloads-new/category/4-multi-module |
Attach your multi-module board to the AVR programmer. The relevant pins on the 8-pin header are: | Attach your multi-module board to the AVR programmer. The relevant pins on the 8-pin header are: | ||
Line 90: | Line 90: | ||
=== Programming with a Devo transmitter === | === Programming with a Devo transmitter === | ||
You need to obtain the avr.hex file from here: | You need to obtain the avr.hex file from here: | ||
- | http://www.deviationtx.com/repository/Multi-Module/ | + | https://www.deviationtx.com/repository/Multi-Module/ |
You also need a custom programming DFU for your transmitter from here: | You also need a custom programming DFU for your transmitter from here: | ||
- | http://www.deviationtx.com/downloads-new/category/7-programmer-dfus# | + | https://www.deviationtx.com/downloads-new/category/7-programmer-dfus# |
- Install the programming DFU for your transmitter with the DFuSe USB Upgrade tool | - Install the programming DFU for your transmitter with the DFuSe USB Upgrade tool |
building_the_multi-module.txt (307552 views) ยท Last modified: 2017/01/23 00:21 by FDR
