development:building_on_windows [2016/04/16 02:05] FDR [Install MingW] |
development:building_on_windows [2016/04/30 08:17] PhracturedBlue |
+ | **NOTE: It is now strongly recommended that you use Docker images to build Deviation. Instructions for building can be found [[development:docker | here]]** | ||
''Note, these instructions may be out of date. Please help to make them current'' | ''Note, these instructions may be out of date. Please help to make them current'' | ||
==== Install MinGW ==== | ==== Install MinGW ==== | ||
Line 5: | Line 7: | ||
Line 16: | Line 18: | ||
* cd src | * cd src |
development/building_on_windows.txt (113059 views) · Last modified: 2016/04/30 08:17 by PhracturedBlue
