development:building_on_windows [2016/04/15 19:03] PhracturedBlue [Running Emulator] |
development:building_on_windows [2016/04/16 02:06] FDR [Install fltk] |
- | ==== Install MingW ==== | + | ''Note, these instructions may be out of date. Please help to make them current'' |
- | * [[http://sourceforge.net/projects/mingw/files/Installer/mingw-get-inst/mingw-get-inst-20120426/mingw-get-inst-20120426.exe/download||Download]] the mingw installer | + | ==== Install MinGW ==== |
+ | * [[http://sourceforge.net/projects/mingw/files/Installer/mingw-get-inst/mingw-get-inst-20120426/mingw-get-inst-20120426.exe/download|Download the MinGW installer]] | ||
Line 26: | Line 27: | ||
* cd ~/src | * cd ~/src | ||
* cp -pf <path to deviation src code> deviation | * cp -pf <path to deviation src code> deviation |
development/building_on_windows.txt (111408 views) · Last modified: 2016/04/30 08:17 by PhracturedBlue
