development:building_on_windows [2016/04/15 19:06] PhracturedBlue |
development:building_on_windows [2016/04/30 08:17] PhracturedBlue |
+ | **NOTE: It is now strongly recommended that you use Docker images to build Deviation. Instructions for building can be found [[development:docker | here]]** | ||
''Note, these instructions may be out of date. Please help to make them current'' | ''Note, these instructions may be out of date. Please help to make them current'' | ||
- | ==== Install MingW ==== | + | ==== Install MinGW ==== |
- | * [[http://sourceforge.net/projects/mingw/files/Installer/mingw-get-inst/mingw-get-inst-20120426/mingw-get-inst-20120426.exe/download||Download]] the mingw installer | + | * [[http://sourceforge.net/projects/mingw/files/Installer/mingw-get-inst/mingw-get-inst-20120426/mingw-get-inst-20120426.exe/download|Download the MinGW installer]] |
Line 16: | Line 18: | ||
* cd src | * cd src | ||
Line 27: | Line 29: | ||
* cd ~/src | * cd ~/src | ||
* cp -pf <path to deviation src code> deviation | * cp -pf <path to deviation src code> deviation |
development/building_on_windows.txt (109027 views) · Last modified: 2016/04/30 08:17 by PhracturedBlue
