development:docker [2016/04/30 06:37] PhracturedBlue |
development:docker [2016/05/16 21:25] RedSleds typo |
- | ===== Building with Docker Image ===== | + | ===== Building with Docker Containers ===== |
==== Background ==== | ==== Background ==== | ||
- | In the past we have found it difficult to provide a reliable build environment that could produce the same results as our nightly builds across multiple operating systems. In the end, we have chosen to use a Docker image to provide an easy to use method to build the Deviation source. A Docker image is a linux image that has been wrapped in a way that it can be run from most any PC and will execute precisely the code that we have specified in exactly the same way regardless of what machine you run it on. | + | In the past we have found it difficult to provide a reliable build environment that could produce the same results as our nightly builds across multiple operating systems. In the end, we have chosen to use a Docker image to provide an easy to use method to build the Deviation source. A Docker image is a Linux environment that has been packaged in a way that it can be run from most any PC and will execute precisely the code that we have specified in exactly the same way regardless of what machine you run it on. |
==== Requirements ==== | ==== Requirements ==== | ||
If you use a Windows PC, you need: | If you use a Windows PC, you need: | ||
- | * A somewhat recent one which can support Virtualization (this is almsot anything made within the last 10 years) | + | * A somewhat recent one which can support Virtualization (this is almost anything made within the last 10 years) |
* Virtualization must be enabled in your BIOS | * Virtualization must be enabled in your BIOS | ||
* You must be running a 64Bit version of Windows | * You must be running a 64Bit version of Windows | ||
Line 15: | Line 15: | ||
- | ==== Running the Docker Image ==== | + | NOTE: I have seen some cases on Windows where the installation seems to go okay, but Docker cannot start. This is an issue with some PCs and VirtualBox (which is installed automatically by Docker). If you see this error when trying to run Docker 'VERR_INTNET_FLT_IF_NOT_FOUND', then the solution seems to be to uninstall VirtualBox, download the latest version from [[https://www.virtualbox.org/wiki/Downloads | VirtualBox]] and install using 'VirtualBox-5.x.y-zzzzzzz-Win -msiparams NETWORKTYPE=NDIS5' |
- | Next, you need to download the Deviation build environment. | + | |
- | Next you will want to create a directory on your PC where the built images can be placed. | + | Next you will want to create a directory on your PC where the built firmware can be placed. |
- | Now it is time to start the Docker image. | + | Now it is time to create the Docker container. |
- | Once your started the Docker image, it will update to the latest version of the build script, and then will try to checkout deviation if you did not provide a GIT repo. Next a menu will be shown which allows you to choose what you would like to build. | + | ==== Building Deviation ==== |
+ | To get started run: ''docker start -i deviation_build'' | ||
+ | Once you've started the Docker container, it will update to the latest version of the build script, and then will try to checkout deviation if you did not provide a GIT repo. Next a menu will be shown which allows you to choose what you would like to build. | ||
+ | Initially, 'default' an 'emu_default' are selected. This will build all zip files that are normally part of a nightly build. | ||
+ | The 'Shell' command will provide an interactive Linux shell inside the image. This is likely only useful for developers or users familiar with Linux | ||
+ | When you press 'Build' the Deviation images you selected will be built. If you selected emulator images, some extra libraries will be automatically downloaded and built first. | ||
+ | For instance: | ||
development/docker.txt (191876 views) · Last modified: 2017/04/10 01:08 by mwm
