development:docker [2016/04/30 07:24] PhracturedBlue |
development:docker [2016/05/11 18:46] PhracturedBlue |
Line 35: | Line 35: | ||
Line 50: | Line 50: | ||
Once your started the Docker container, it will update to the latest version of the build script, and then will try to checkout deviation if you did not provide a GIT repo. Next a menu will be shown which allows you to choose what you would like to build. | Once your started the Docker container, it will update to the latest version of the build script, and then will try to checkout deviation if you did not provide a GIT repo. Next a menu will be shown which allows you to choose what you would like to build. | ||
- | {{:development:docker_screen.png?200|}} | + | {{:development:docker_screen.png?600|}} |
Initially, 'default' an 'emu_default' are selected. This will build all zip files that are normally part of a nightly build. | Initially, 'default' an 'emu_default' are selected. This will build all zip files that are normally part of a nightly build. | ||
Line 61: | Line 61: | ||
+ | For instance: | ||
development/docker.txt (191878 views) ยท Last modified: 2017/04/10 01:08 by mwm
