development:docker [2016/07/06 20:17] Arnold [Building the Deviation Manual] |
Line 35: | Line 35: | ||
Line 48: | Line 48: | ||
Line 61: | Line 61: | ||
+ | For instance: | ||
+ | Run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment | ||
development/docker.txt (191228 views) ยท Last modified: 2017/04/10 01:08 by mwm
