development:docker [2016/05/16 21:25] RedSleds typo |
Line 35: | Line 35: | ||
- | ''docker create -it -v ~/devo_builds:/release ---name deviation_build deviationtx/deviation-docker'' | + | ''<nowiki>docker create -it -v ~/devo_builds:/release --name deviation_build deviationtx/deviation-docker</nowiki>'' |
Line 48: | Line 48: | ||
Line 61: | Line 61: | ||
+ | For instance: | ||
development/docker.txt (189603 views) ยท Last modified: 2017/04/10 01:08 by mwm
