development:docker [2016/05/11 07:08] PhracturedBlue |
Line 11: | Line 11: | ||
Line 48: | Line 52: | ||
Line 70: | Line 74: | ||
Note that unlike using the gui included with the Docker image, the results will not be copied to the /release directory, and instead will remain in the deviation/src dir. Also, any pre-configuration needs to be done through the docker image gui (for instance if you want to build the windows emulator, you must have built it once through the gui to make sure all required software is installed) | Note that unlike using the gui included with the Docker image, the results will not be copied to the /release directory, and instead will remain in the deviation/src dir. Also, any pre-configuration needs to be done through the docker image gui (for instance if you want to build the windows emulator, you must have built it once through the gui to make sure all required software is installed) | ||
development/docker.txt (180149 views) · Last modified: 2017/04/10 01:08 by mwm
