development:docker [2016/05/11 18:46] PhracturedBlue |
Line 48: | Line 48: | ||
Line 73: | Line 73: | ||
==== Building the Deviation Manual ==== | ==== Building the Deviation Manual ==== | ||
- | After creating the Docker container, start docekr and enter the Shell. | + | After creating the Docker container, start docker and enter the Shell. |
''cd /git; git clone https://github.com/DeviationTX/deviation-manual'' | ''cd /git; git clone https://github.com/DeviationTX/deviation-manual'' | ||
- | For instance, from within the docker shell and run: | + | |
Or from outside the docker shell (note that this assumes you have added dmake to your PATH): | Or from outside the docker shell (note that this assumes you have added dmake to your PATH): | ||
''cd <path to git repo>/deviation-manual'' | ''cd <path to git repo>/deviation-manual'' | ||
''dmake TARGET=devo8 html pdf'' | ''dmake TARGET=devo8 html pdf'' | ||
development/docker.txt (179328 views) · Last modified: 2017/04/10 01:08 by mwm
