development:docker [2016/05/16 21:25] RedSleds typo |
development:docker [2016/07/08 19:09] Arnold [Building Deviation] |
Line 52: | Line 52: | ||
Line 73: | Line 73: | ||
==== Building the Deviation Manual ==== | ==== Building the Deviation Manual ==== | ||
- | After creating the Docker container, start docekr and enter the Shell. | + | After creating the Docker container, start docker and enter the Shell. |
- | run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment | + | Run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment |
Line 81: | Line 81: | ||
- | For instance, from within the docker shell and run: | + | For instance, from within the docker shell run: |
development/docker.txt (179901 views) · Last modified: 2017/04/10 01:08 by mwm
