development:docker [2016/07/06 20:15] Arnold [Building the Deviation Manual] |
development:docker [2016/07/08 19:09] Arnold [Building Deviation] |
Line 52: | Line 52: | ||
Line 74: | Line 74: | ||
- | run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment | + | Run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment |
Line 81: | Line 81: | ||
- | For instance, from within the docker shell and run: | + | For instance, from within the docker shell run: |
development/docker.txt (179997 views) ยท Last modified: 2017/04/10 01:08 by mwm
