Line 11: | Line 11: | ||
Line 35: | Line 39: | ||
- | ''docker create -it -v ~/devo_builds:/release ---name deviation_build deviationtx/deviation-docker'' | + | ''<nowiki>docker create -it -v ~/devo_builds:/release --name deviation_build deviationtx/deviation-docker</nowiki>'' |
Line 48: | Line 52: | ||
Line 61: | Line 65: | ||
+ | For instance: | ||
development/docker.1462841199.txt.gz (180260 views) · Last modified: 2016/05/09 17:46 by HappyHarry
