development:docker [2016/05/11 18:46] PhracturedBlue [Building the Deviation Manual] |
Line 48: | Line 48: | ||
Line 73: | Line 73: | ||
==== Building the Deviation Manual ==== | ==== Building the Deviation Manual ==== | ||
- | After creating the Docker container, start docekr and enter the Shell. | + | After creating the Docker container, start docker and enter the Shell. |
''cd /git; git clone https://github.com/DeviationTX/deviation-manual'' | ''cd /git; git clone https://github.com/DeviationTX/deviation-manual'' | ||
- | For instance, from within the docker shell and run: | + | |
development/docker.txt (172419 views) · Last modified: 2017/04/10 01:08 by mwm
