development:docker [2016/05/16 21:25] RedSleds typo |
Line 11: | Line 11: | ||
Line 52: | Line 53: | ||
Line 73: | Line 74: | ||
==== Building the Deviation Manual ==== | ==== Building the Deviation Manual ==== | ||
- | After creating the Docker container, start docekr and enter the Shell. | + | After creating the Docker container, start docker and enter the Shell. |
Line 81: | Line 82: | ||
- | For instance, from within the docker shell and run: | + | For instance, from within the docker shell run: |
development/docker.txt (168292 views) · Last modified: 2017/04/10 01:08 by mwm
