development:docker [2016/07/08 19:09] Arnold [Building Deviation] |
Line 11: | Line 11: | ||
Line 74: | Line 78: | ||
- | Run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment | + | Run: ''%%sudo /root/build.py --manual-prereq%%'' to install the necessary build environment |
Next (still from the docker shell), run: | Next (still from the docker shell), run: |
development/docker.txt (168379 views) · Last modified: 2017/04/10 01:08 by mwm
