development:docker [2016/04/30 07:08] PhracturedBlue |
Line 11: | Line 11: | ||
- | ==== Running the Docker Container ==== | + | NOTE: I have seen some cases on Windows where the installation seems to go okay, but Docker cannot start. This is an issue with some PCs and VirtualBox (which is installed automatically by Docker). If you see this error when trying to run Docker 'VERR_INTNET_FLT_IF_NOT_FOUND', then the solution seems to be to uninstall VirtualBox, download the latest version from [[https://www.virtualbox.org/wiki/Downloads | VirtualBox]] and install using 'VirtualBox-5.x.y-zzzzzzz-Win -msiparams NETWORKTYPE=NDIS5' |
- | Next, you need to download the Deviation build environment. | + | |
Next you will want to create a directory on your PC where the built firmware can be placed. | Next you will want to create a directory on your PC where the built firmware can be placed. | ||
- | Now it is time to start the Docker container. | + | Now it is time to create the Docker container. |
- | Once your started the Docker container, it will update to the latest version of the build script, and then will try to checkout deviation if you did not provide a GIT repo. Next a menu will be shown which allows you to choose what you would like to build. | + | ==== Building Deviation ==== |
- | {{:development:docker_screen.png?200|}} | + | To get started run: ''docker start -i deviation_build'' |
- | Initially, 'default' an 'emu_default' are selected. This will build all zip files that are normally part of a nightly build. | + | Once you've started the Docker container, it will update to the latest version of the build script, and then will try to checkout deviation if you did not provide a GIT repo. Next a menu will be shown which allows you to choose what you would like to build. |
+ | Initially, 'default' and 'emu_default' are selected. This will build all zip files that are normally part of a nightly build. | ||
Line 49: | Line 64: | ||
+ | For instance: | ||
development/docker.1462025332.txt.gz (167124 views) · Last modified: 2016/04/30 07:08 by PhracturedBlue
