development:docker [2016/07/06 20:17] Arnold [Building the Deviation Manual] |
Line 11: | Line 11: | ||
Line 52: | Line 56: | ||
Line 74: | Line 78: | ||
- | Run: ''sudo /root/build.py --manual-prereq'' to install the necessary build environment | + | Run: ''%%sudo /root/build.py --manual-prereq%%'' to install the necessary build environment |
Next (still from the docker shell), run: | Next (still from the docker shell), run: |
development/docker.1467861425.txt.gz (167113 views) · Last modified: 2016/07/06 20:17 by Arnold
