Line 17: | Line 17: | ||
* For example: ''export PATH="/c/Program Files/Python27":$PATH)'' | * For example: ''export PATH="/c/Program Files/Python27":$PATH)'' | ||
- | ==== Builing the Windows binary on Linux ==== | + | ==== Building the Windows binary on Linux ==== |
First install fltk: | First install fltk: | ||
apt-get install mingw32 mingw32-binutils mingw32-runtime | apt-get install mingw32 mingw32-binutils mingw32-runtime | ||
Line 65: | Line 65: | ||
+ | * Building the emulator is done by pre-pending 'emu_': ''make emu_devo8'' or ''make zip_emu_devo8'' | ||
development/setting_up_build_env.txt (25501 views) ยท Last modified: 2019/03/04 20:06 by csujun
