development:setting_up_build_env [2016/04/30 08:06] PhracturedBlue |
development:setting_up_build_env [2016/04/30 08:07] PhracturedBlue |
Line 68: | Line 68: | ||
==== Building Deviation ==== | ==== Building Deviation ==== | ||
- | The default build target is the devo8 transmitter. If you type ''make'' in the deviation/src directory this is what you will get. | + | * The default build target is the devo8 transmitter. If you type ''make'' in the deviation/src directory this is what you will get. |
- | Other transmitters can be specified on the make cmdline: ''make devo10 devo7e'' | + | * Other transmitters can be specified on the make cmdline: ''make devo10 devo7e'' |
- | Creating packaged zip files can be done by pre-pending 'zip_': ''make zip_devo10'' | + | * Creating packaged zip files can be done by pre-pending 'zip_': ''make zip_devo10'' |
- | Building the emulator is done by pre-pending 'emu-': ''make emu_devo8'' or ''make _zip_emu_devo8'' | + | * Building the emulator is done by pre-pending 'emu-': ''make emu_devo8'' or ''make _zip_emu_devo8'' |
- | Building the windows version of the emulator can be done vie: ''make win_emu_devo8'' or ''make zip_win_emu_devo8'' | + | * Building the windows version of the emulator can be done vie: ''make win_emu_devo8'' or ''make zip_win_emu_devo8'' |
development/setting_up_build_env.txt (20833 views) ยท Last modified: 2019/03/04 20:06 by csujun
