development:setting_up_build_env [2016/04/30 07:30]
PhracturedBlue created
development:setting_up_build_env [2019/03/04 20:06] (current)
csujun update gcc-8
Line 1: Line 1:
-===== Setting ​UP the Deviation Build Environment =====+===== Setting ​Up the Deviation Build Environment =====
-**NOTE: It is now strongly recommended that you use Docker images to build Deviation. ​ Instructions for building can be found [[development:​docker | here]].+**NOTE: It is now strongly recommended that you use Docker images to build Deviation. ​ Instructions for building can be found [[development:​docker | here]]**
 +==== Building for ARM (on Linux) ====
 +  - download and install the pre-compiled Linux compiler from here: https://​developer.arm.com/​open-source/​gnu-toolchain/​gnu-rm/​downloads
 +    * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-8-2018-q4. ​ You can find the link to this from here: https://​developer.arm.com/​-/​media/​Files/​downloads/​gnu-rm/​8-2018q4/​gcc-arm-none-eabi-8-2018-q4-major-linux.tar.bz2
 +  - Add the path to the '​bin'​ directory to your PATH
 +==== Building for ARM (on Windows) ====
 +  - Download and install the precompiled windows compiler from here: https://​developer.arm.com/​open-source/​gnu-toolchain/​gnu-rm/​downloads
 +    * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-8-2018-q4. ​ You can find the link to this from here: https://​armkeil.blob.core.windows.net/​developer/​Files/​downloads/​gnu-rm/​8-2018q4/​gcc-arm-none-eabi-8-2018-q4-major-win32.zip
 +  - Add path to '​bin'​ directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''​export PATH=/​mingw/​stm32/​bin:​$PATH''​
 +  - Ensure python is installed. ​ If not install it from here: http://​www.python.org/​download/​releases/​2.7.3/​
 +  - Add python to your msys path: ''​export PATH="/​c/<​path to python>":​$PATH''​
 +    * For example: ''​export PATH="/​c/​Program Files/​Python27":​$PATH)''​
 +==== Building the Windows binary on Linux ====
 +First install fltk:
 +  apt-get install mingw32 mingw32-binutils mingw32-runtime
 +  <​Download and unpack fltk source code>
 +  ./configure --disable-largefile --enable-localjpeg \
 +           ​--enable-localzlib --enable-localpng \
 +           ​--disable-gl --host=i586-mingw32msvc \
 +           ​--prefix=/​opt/​fltk-w32
 +  make
 +  sudo make install
 +Next install portaudio:​
 +  <​Download and unpack portaudio source code>
 +  ./configure --prefix=/​opt/​portaudio-w32
 +  make
 +  sudo make install
 +==== Building the Windows binary on Windows ====
 +First install MingW:
 +  * Download the mingw installer as per: http://​www.mingw.org/​wiki/​Getting_Started
 +  * Run the installer, and select '​C++',​ '​MSYS'​ and the '​Developer Toolkit'​
 +Next, install fltk:
 +  * Download fltk from here: http://​fltk.org/​software.php?​VERSION=1.3.0&​FILE=fltk/​1.3.0/​fltk-1.3.0-source.tar.gz
 +  * Start msys (you should have an icon, but otherwise run C:​\MingW\msys\1.0\msys.bat
 +  * mkdir src
 +  * cd src
 +  * Untar fltk: tar -xzf <path to fltk download>​ (you can get to your C: drive in mingw using /​c/​Users/<​user>/​Downloads for example)
 +  * cd fltk-1.3.0
 +  * ./​configure
 +  * make
 +  * make install
 +Then, install portaudio:​
 +  * Download portaudio from here: http://​www.portaudio.com/​archives/​pa_stable_v19_20111121.tgz
 +  * cd src
 +  * Untar portaudio: tar -xzf <path to portaudio download>​ (you can get to your C: drive in mingw using /​c/​Users/<​user>/​Downloads for example)
 +  * cd portaudio
 +  * ./​configure
 +  * make
 +  * make install
 +Finally, install Deviation:​
 +  * Download the source code for deviation. You'll need mercurial to keep track of changes (which will require installing python), but you can manually download a zip of the source from bitbucket.org/​PhracturedBlue/​deviation
 +  * cd ~/src
 +  * cp -pf <path to deviation src code> deviation
 +  * cd deviation/​src
 +==== Building Deviation ====
 +  * The default build target is the devo8 transmitter. ​ If you type ''​make''​ in the deviation/​src directory this is what you will get.
 +  * Other transmitters can be specified on the make cmdline: ​ ''​make devo10 devo7e''​
 +  * Creating packaged zip files can be done by pre-pending '​zip_':​ ''​make zip_devo10''​
 +  * Building the emulator is done by pre-pending '​emu_':​ ''​make emu_devo8''​ or ''​make zip_emu_devo8''​
 +  * Building the windows version of the emulator can be done vie: ''​make win_emu_devo8'' ​ or ''​make zip_win_emu_devo8''​
development/setting_up_build_env.1462026646.txt.gz (125229 views) · Last modified: 2016/04/30 07:30 by PhracturedBlue
