development
development [2016/04/30 07:27] PhracturedBlue |
development [2016/04/30 07:33] PhracturedBlue |
Instructions for building Deviation with Docker can be found [[development:docker | here]] | Instructions for building Deviation with Docker can be found [[development:docker | here]] | ||
- | If you want to just look at the code, build the emulators, or try your hands at rolling your own build environment, the Deviation GitHub repository is [[https://github.com/DeviationTX/deviation | here]]. Instructions for a manual build can be found there as well. | + | If you want to look at the code, the Deviation GitHub repository is [[https://github.com/DeviationTX/deviation | here]]. |
+ | The legacy instructions on setting up the build environment by hand can be found [[development:setting_up_build_env | here]], but this method is no longer recommended. | ||
Some users have also tried various build approaches. These are generally less well supported, but alternate instructions for building on Windows can be found [[development:building_on_windows | here]], and instructions for building with Eclipse are available [[development:building_with_eclipse | here]]. | Some users have also tried various build approaches. These are generally less well supported, but alternate instructions for building on Windows can be found [[development:building_on_windows | here]], and instructions for building with Eclipse are available [[development:building_with_eclipse | here]]. |
development.txt (61295 views) · Last modified: 2017/01/23 00:22 by FDR
