faq [2016/04/14 20:55] PhracturedBlue |
- | {{INLINETOC}} | + | {{INLINETOC:3-4}} |
Line 22: | Line 22: | ||
- | Deviation with the additional RF modules already supports a lot of protocols, and the number is increasing day after day. You can look at the Supported Models list to see, if your model is supported. | + | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see, if your model is supported. |
Line 37: | Line 37: | ||
Line 53: | Line 52: | ||
faq.txt (99065 views) ยท Last modified: 2017/01/23 00:24 by FDR
