faq [2016/04/15 02:20] FDR [I have a <insert brand> receiver, can it be supported?] |
faq [2016/06/10 12:47] Arnold [HELP! My transmitter won't go into DFU mode] |
Line 22: | Line 22: | ||
- | The Walkera Devo transmitters use a CYRF6936 transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/cc2500|CC2500]], [[modulelist/a7105|A7105]], [[modulelist/nrf24l01|NRF74L01]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/multimod|MultiModule]]. | + | The Walkera Devo transmitters use a [[modulelist/cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/cc2500|CC2500]], [[modulelist/a7105|A7105]], [[modulelist/nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/multimod|MultiModule]]. |
Line 37: | Line 37: | ||
- | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. | + | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. (On the Devo 12 & 12S, use the trainer switch instead - it's on the right-rear side of the controller.) |
Line 53: | Line 52: | ||
faq.txt (111988 views) ยท Last modified: 2017/01/23 00:24 by FDR
