faq [2016/06/10 12:47] Arnold [HELP! My transmitter won't go into DFU mode] |
Line 24: | Line 24: | ||
Line 37: | Line 37: | ||
- | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. | + | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. (On the Devo 12 & 12S, use the trainer switch instead - it's on the right-rear side of the controller.) |
Line 53: | Line 52: | ||
faq.txt (111986 views) ยท Last modified: 2017/01/23 00:24 by FDR
