faq [2016/04/15 08:46] FDR [Can you answer a question about my stock Devo transmitter?] |
faq [2016/06/10 12:48] Arnold [HELP! My transmitter won't go into DFU mode] |
Line 24: | Line 24: | ||
Line 37: | Line 37: | ||
To switch into the USB mode you need to turn on the TX while holding the 'ENT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'ENT' button, which is on the right side of the display. | To switch into the USB mode you need to turn on the TX while holding the 'ENT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'ENT' button, which is on the right side of the display. |
faq.txt (113572 views) ยท Last modified: 2017/01/23 00:24 by FDR
