faq [2016/06/10 10:37] FDR [I have a <insert brand> receiver, can it be supported?] |
Line 22: | Line 22: | ||
Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see, if your model is supported. | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see, if your model is supported. | ||
Line 37: | Line 37: | ||
Line 55: | Line 54: | ||
A lot of TX experts are here, so probably yes. Ask your question in the [[http://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. | A lot of TX experts are here, so probably yes. Ask your question in the [[http://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. | ||
faq.txt (102787 views) ยท Last modified: 2017/01/23 00:24 by FDR
