faq [2016/06/10 12:47] Arnold [HELP! My transmitter won't go into DFU mode] |
faq [2016/06/10 12:48] Arnold [HELP! My transmitter won't go into DFU mode] |
Line 37: | Line 37: | ||
- | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. (On the Devo 12 & 12S, use the trainer switch instead - it's on the right-rear side of the controller.) | + | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. (On the Devo 12/12S, use the trainer switch instead - it's on the right-rear side of the controller.) |
If the TX won't go into the DFU mode, or doesn't show any sign of life, pull out the batteries for some time (say 15 minutes), and try again. | If the TX won't go into the DFU mode, or doesn't show any sign of life, pull out the batteries for some time (say 15 minutes), and try again. |
faq.txt (116738 views) ยท Last modified: 2017/01/23 00:24 by FDR
