faq [2016/06/25 07:39] Tom Z |
Line 22: | Line 22: | ||
- | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see, if your model is supported. | + | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see if your model is supported. |
In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip. | In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip. |
faq.txt (100942 views) ยท Last modified: 2017/01/23 00:24 by FDR
