Line 22: | Line 22: | ||
- | The Walkera Devo transmitters use a CYRF6936 transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/cc2500|CC2500]], [[modulelist/a7105|A7105]], [[modulelist/nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/multimod|MultiModule]]. | + | The Walkera Devo transmitters use a [[modulelist/cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/cc2500|CC2500]], [[modulelist/a7105|A7105]], [[modulelist/nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/multimod|MultiModule]]. Alternatively, the [[modulelist/3-in-1 module|3-in-1]] and [[modulelist/4-in-1 module|4-in-1]] Modules are popular options. |
Line 37: | Line 37: | ||
Line 53: | Line 52: | ||
faq.txt (91954 views) ยท Last modified: 2017/01/23 00:24 by FDR
