faq [2016/06/25 07:39] Tom Z |
faq [2017/01/23 00:24] FDR https |
Line 22: | Line 22: | ||
- | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see, if your model is supported. | + | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see if your model is supported. |
Line 52: | Line 52: | ||
- | A lot of TX experts are here, so probably yes. Ask your question in the [[http://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. | + | A lot of TX experts are here, so probably yes. Ask your question in the [[https://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. |
==== Are version 4.0.1 models compatible with version 5 firmware? ==== | ==== Are version 4.0.1 models compatible with version 5 firmware? ==== | ||
There shouldn't be any compatibility issues. | There shouldn't be any compatibility issues. |
faq.txt (92700 views) ยท Last modified: 2017/01/23 00:24 by FDR
