get_started_with_deviationtx [2016/04/13 08:17] FDR removed F4 |
+ | Devo 10 | ||
Line 10: | Line 10: | ||
Line 17: | Line 17: | ||
- | * **Nightly Builds** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. | + | * **[[https://www.deviationtx.com/downloads-new/category/13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. |
- | * **Test releases** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. | + | * **[[https://www.deviationtx.com/downloads-new/category/32-test-builds|Test releases]]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. |
Line 45: | Line 45: | ||
- | You can find ready to use [[http://www.deviationtx.com/forum/model-configs|model configs]] in the forum for your models, which you can download, and simply copy into your TX through USB, just like you copy to any USB drive. | + | You can find ready to use [[https://www.deviationtx.com/forum/model-configs|model configs in the forum]] or in the [[model_config|Wiki]] for your models, which you can download, and simply copy into your TX through USB, just like you copy to any USB drive. |
- | ...always look for an answer first in the [[Frequently Asked Questions (FAQ)]] list. | + | ...always look for an answer first in the [[faq|Frequently Asked Questions (FAQ)]] list. |
get_started_with_deviationtx.txt (103321 views) · Last modified: 2020/01/31 12:43 by laurent_martin
