get_started_with_deviationtx [2016/04/15 01:07] FDR [Ready to fly (or drive, or sail, or whatever)] |
Line 10: | Line 10: | ||
Line 17: | Line 17: | ||
- | * **Nightly Builds** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. | + | * **[[https://www.deviationtx.com/downloads-new/category/13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. |
- | * **Test releases** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. | + | * **[[https://www.deviationtx.com/downloads-new/category/32-test-builds|Test releases]]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. |
Line 45: | Line 45: | ||
- | You can find ready to use [[http://www.deviationtx.com/forum/model-configs|model configs in the forum]] or in the Wiki for your models, which you can download, and simply copy into your TX through USB, just like you copy to any USB drive. | + | You can find ready to use [[https://www.deviationtx.com/forum/model-configs|model configs in the forum]] or in the [[model_config|Wiki]] for your models, which you can download, and simply copy into your TX through USB, just like you copy to any USB drive. |
Line 59: | Line 59: | ||
- | If you haven't found an answer for your particular question, just ask away in the [[http://www.deviationtx.com/forum|Forum]]. However when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. | + | The [[Programming guides|Tutorials and How To's]] can also be helpful. |
get_started_with_deviationtx.txt (88134 views) · Last modified: 2020/01/31 12:43 by laurent_martin
