get_started_with_deviationtx [2016/04/15 02:12] FDR [Ready to fly (or drive, or sail, or whatever)] |
+ | Devo 10 | ||
Line 10: | Line 10: | ||
Line 17: | Line 17: | ||
- | * **Nightly Builds** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. | + | * **[[https://www.deviationtx.com/downloads-new/category/13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. |
- | * **Test releases** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. | + | * **[[https://www.deviationtx.com/downloads-new/category/32-test-builds|Test releases]]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. |
Line 45: | Line 45: | ||
Line 59: | Line 59: | ||
get_started_with_deviationtx.txt (86748 views) · Last modified: 2020/01/31 12:43 by laurent_martin
