get_started_with_deviationtx [2016/04/15 02:27] FDR [Install deviation] |
Line 10: | Line 10: | ||
Line 17: | Line 17: | ||
- | * **[[http://www.deviationtx.com/downloads-new/category/32-test-builds|Test releases]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. | + | * **[[https://www.deviationtx.com/downloads-new/category/32-test-builds|Test releases]]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build. |
Line 45: | Line 45: | ||
Line 59: | Line 59: | ||
- | If you haven't found an answer for your particular question, just ask away in the [[http://www.deviationtx.com/forum|Forum]]. However when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. | + | The [[Programming guides|Tutorials and How To's]] can also be helpful. |
get_started_with_deviationtx.txt (87649 views) · Last modified: 2020/01/31 12:43 by laurent_martin
