get_started_with_deviationtx [2016/04/15 02:27] FDR [Install deviation] |
get_started_with_deviationtx [2017/03/16 09:25] thanh1516 [First you need a TX] |
- | + | \\devo 7e | |
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, F4, F7 and F12E, and you can read some opinions here: [[Which Devo TX should I buy?]] | + | ...if you don't have one already. The currently supported models include the 6, 6S, 7E. |
Line 10: | Line 8: | ||
Line 17: | Line 15: | ||
Line 45: | Line 43: | ||
Line 59: | Line 57: | ||
get_started_with_deviationtx.txt (87060 views) · Last modified: 2020/01/31 12:43 by laurent_martin
