get_started_with_deviationtx [2016/04/15 03:26] FDR [First you need a TX] |
get_started_with_deviationtx [2016/10/04 08:47] extrawai [Getting started with deviationTx] |
- | + | \\devo 1o | |
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, F4, F7 and F12E, and you can read some opinions here: [[http://www.deviationtx.com/articles/21-which-devo-tx-should-i-buy|Which Devo TX should I buy?]] | + | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] |
Line 17: | Line 16: | ||
- | You can read the actual documentation online by clicking on the appropriate User Manual submenu on the left ([[http://www.deviationtx.com/user-manual/user-manual-6-8-12|User Manual for DEVO 6/8/12]], [[http://www.deviationtx.com/user-manual/user-manual-7e-10|User Manual for DEVO 7E/10]]), or you can download it as a PDF ([[https://bitbucket.org/deviationtx/deviation-manual-rst/downloads/Deviation8UsersManual.pdf|User Manual for DEVO 6/8/12]], [[https://bitbucket.org/deviationtx/deviation-manual-rst/downloads/Deviation10UsersManual.pdf|User Manual for DEVO 7E/10]]). | + | You can read the actual documentation online by clicking on the appropriate User Manual submenu on the left ([[http://www.deviationtx.com/user-manual/user-manual-6-8-12|DEVO 6/8/12]], [[http://www.deviationtx.com/user-manual/user-manual-7e-10|DEVO 7E/10]]), or you can download it as a PDF ([[https://bitbucket.org/deviationtx/deviation-manual-rst/downloads/Deviation8UsersManual.pdf|DEVO 6/8/12]], [[https://bitbucket.org/deviationtx/deviation-manual-rst/downloads/Deviation10UsersManual.pdf|DEVO 7E/10]]). |
Line 26: | Line 25: | ||
* **[[http://www.deviationtx.com/downloads-new/category/13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. | * **[[http://www.deviationtx.com/downloads-new/category/13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too. | ||
Line 35: | Line 34: | ||
Line 50: | Line 49: | ||
Line 59: | Line 58: | ||
- | If you haven't found an answer for your particular question, just ask away in the [[http://www.deviationtx.com/forum|Forum]]. However when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. | + | If you haven't found an answer for your particular question, just ask away in the [[http://www.deviationtx.com/forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. |
get_started_with_deviationtx.txt (89137 views) · Last modified: 2020/01/31 12:43 by laurent_martin
