get_started_with_deviationtx [2016/04/15 03:26] FDR [First you need a TX] |
- | + | \\devo 7e | |
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, F4, F7 and F12E, and you can read some opinions here: [[http://www.deviationtx.com/articles/21-which-devo-tx-should-i-buy|Which Devo TX should I buy?]] | + | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] |
+ | Devo 10 | ||
Line 10: | Line 9: | ||
Line 17: | Line 16: | ||
Line 45: | Line 44: | ||
Line 59: | Line 58: | ||
get_started_with_deviationtx.txt (85180 views) · Last modified: 2020/01/31 12:43 by laurent_martin
